09-16-2022 11:15 AM
I just uprgradedto the visible + and it won’t load on my phone need asap help
09-16-2022 01:35 PM
Are you running the latest Visible app?
If it’s a Droid you may need to modify the APN
Here are the latest APN settings I have, BUT do a community search if they don’t work (I’m on iOS)
APN name: Verizon 2
APN: vzwinternet
MMS port: 80
MCC: 311
MNC: 480
Apn protocol: iPv4/iPv6
Apn roaming protocol: iPv4/iPv6
APN type: default,supl,mms
Leave all other fields blank, and save this configuration.
Restart the phone
09-17-2022 07:25 PM
What issue do you have? what's not loading the eSIM or data?
