β11-02-2021 04:50 PM
β11-03-2021 12:51 PM
They run off of Verizon's network. I would imagine that you would have great coverage there. According to their coverage map, you have 5G coverage (at least 200 Mbps). https://www.visible.com/plan/coverage
β11-04-2021 12:46 AM
My best advice for you: do the Swap, get a free phone & see how the service is for you. Your first month will only cost $5 with a referral, and decide for yourself if the service is acceptable to you.
