Switching from mint to visible
samuelowusu
Please I want to switch from Mint to visible and I am using the physical sim what should I do
Ensure your phone is unlocked; then go over to https://www.visible.com/ where you can check its compatibility and order a physical sim and plan. Wait for it to arrive and activate it.
