Using Visible to make calls to the US from Costa Rica
Pebbles
Hello,
Is it possible to use Visible to make calls to the US (landlines and cell phones) from Costa Rica.  I am also needing to be able to receive SMS messages and phone calls back to me.  Thank you!
No, not according to the details on either plan. You can only call from Canada and Mexico.
It is possible, but through WiFi calling. Make sure the device you have support Wifi calling and enable WiFi calling before leaving US (Visible network)
Note: You can call only if you have a wifi connection. Not otherwise.
Please mark this as solution if it helped you.
