Purchasing Plan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
โ05-18-2022 06:02 AM
I'm trying to purchase a Party Pay plan, however, it is not stating that at checkout. Did I miss something?? I did the refer a friend for $5.00 for first month, but it's showing $40 - $35 and doesn't ask if I want the Party Plan. Help??
Labels:
- Labels:
Party Pay
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โ05-18-2022 07:27 AM
Good morning, the party pay system is not a plan you purchase, you have to join a party pay by using a link that someone gives you or you find online. There are many posts with party pay links posted in the 'savings' section of the forum.
More information on the party pay system: https://www.visible.com/plan/party-pay
