Switching tomorrow & Questions
sportsfan7702
I have a refferal code for tomorrow's switch, but I was wondering if in the port in process switching from Mint, besides the pin and other things I have when I go to CS to port in, will they talk to mint through the imei (which is compatible) or do I need to do something on my part?
beav
As long as you answer all the questions with the correct info (don't mistype something) Visible should handle the rest.
Do not cancel your Mint service before the transfer happens. In fact, Mint should cancel your Mint service once the port is complete.
Welcome aboard!
