porting from another carrier with 2 lines, must i set up an account for each line?
cuke
Porting from TMO and utilizing the $15.00 deal. However I have two lines I need to port. what is the secret? do i actually create an account for each line? Am I missing something?
Yes, you need an account/email address for each line. Visible is single line accounts and doesn't have a family plan or family accounts.
Yes you need a separate email and password for each account.  I believe you can use the same payment method for both accounts.  The reason this is the case is because Visible doesn't have family plans.  If you find this answer helpful please mark it as a solution.  Thank you!
