visible lies and service that doesn't actually work
boldgear5114
Thanks for nothing, Visible.  Your "customer service" reps have repeatedly lied.  You charge customers for a service that doesn't work.  Shame on you.
I realize this post will do absolutely nothing (non existent complaint resolution within Visible).  Following other's suggestions to file complains with fed & state agencies next.  That won't help me, but maybe it will force visible's hand in the future.
RyanBlakeIT
Hi @boldgear5114, would you please describe the issues you're having with your service so others may benefit?
